Topic: I HEAR THE 2 SONGS TOGETHER-PLEASE HELP
hello
i think that i made a mistake in the settings of the vdj7pro:
i can hear the 2 songs played in the 2 decks bearing in mind that i use 2 sound cards (Master+USB/headphone),
in the master i can listen to the 2 tracks played and the crossfade is 100% on A
i have reset the factory settings and same problem.
i deleted my data and settings: problem resolved but i my data has been deleted!!!
please help..i have a party tomorrow and i wana use my laptop!!!
thanks
Posted Thu 14 Aug 14 @ 10:14 am
NDIAMADIS wrote :
hello
thanks
I'm confused. You say you have VDJ Pro, but your profile says you are a home user. Please register your pro version, if you have it. You also say, "I deleted my data and settings, but my data has been deleted!!!". If you delete your data and settings, it get's..............deleted. I'm not sure why you would do that, to get your sound card working. What soundcard are you using? You may try to undo this, by going back to a restore point, if you set one.
