could anyone advise me on the correct audio set up for the DDJ SX to enable me to cue track via my headphones.
As it stands I have sound running out of the controller into some active speakers and all of that works fine but if I hit the cue button on any of the channels I can't hear anything in the cans - I know its to do with my audio settings but for the life of me I cannot work out what !!
I'm using VDJ8 by the way and connecting through a Win7 desktop
Many thanks
Many thanks
Posted Wed 13 Aug 14 @ 6:01 pm
Hi Soulboy1970, here are my settings:
OUTPUT: SPEAKER + HEADPHONES
CARD: PIONEER
INPUT: NONE
Source: SoundCard: Channel:
master. Pioneer DDJ_SX ASIO (ASIO) Chan 1&2
Headphones Pioneer DDJ_SX ASIO (ASIO). Chan 3&4
VDJ 8 should automatically detect the DDJ SX sound card. Hope this helps.
CARD: PIONEER
INPUT: NONE
Posted Wed 13 Aug 14 @ 7:42 pm
kaise name set kiya jata hai
Posted Thu 14 Aug 14 @ 12:36 am
Many thanks Latin Lou I will give that a try later
Posted Thu 14 Aug 14 @ 4:08 am
Let me know if you are still having issues. Those are the settings without having the unit actually hooked up. If they don't work I'll power it up to see if there was something I missed.
Posted Thu 14 Aug 14 @ 5:50 pm
Thank you will do but prob won't know until next week
Posted Thu 14 Aug 14 @ 6:43 pm
No problem.
Posted Fri 15 Aug 14 @ 5:59 pm
Hi just to let you know that all works perfectly now - thanks for the help much appriciated
Posted Mon 18 Aug 14 @ 8:29 am
You're welcome. Glad I could help.
Posted Mon 18 Aug 14 @ 7:39 pm
