Topic: How to add Flanged LoopOut v2.0 effect to VDJ8
I read the manual but I didn't see where you can add more effects like Flanged LoopOut.
Thanks!
Posted Tue 05 Aug 14 @ 5:22 pm
add fx or 32 bit vst .dlls to
C:\Users\YourPCname\Documents\VirtualDJ\Plugins\SoundEffect
You'll then find them in the effects list
it doesnt work right, well not on my end, its distorted and has a load click when it deactivates
Oh yeah LoopOut doesn't play nice with V8
Hopefully they will fix it soon
I just been loop the point were I need to stop and fade it out at the same time,it was tricky @ 1st but after practice and practice were the best sound or beat it works.( looping and using the fader down at the same time) not the crossfade.
Isn't there a synced sweep filter? With a bit of hex trickery you could have both HP & LP, but I'm not sure cos I can't get it.
I love that effect, but I agree that it doesn't always work right on VDJ8.
how do I get it though
Sorry buddy but most of the audio fx are only available to pro licence holders, you can however use 32b VSTs.
