Topic: Skin problem on vj8
Im using the internal mixer green skin on vdj 7 but when I bring the same skin up on version 8, it comes out too big and all the eq levels are at the minus position and you can't adjust them. Im very comfortable with this skin so is there any way I can use it or am I doing something wrong ?
Posted Sun 03 Aug 14 @ 1:27 pm
You mean this one?
It was written for VDJ 5 so many of the commands in the skin XML will have changed.
It's not too hard to go through the code and update them yourself (I've been doing it on another old skin) .
Thanks for the reply. Yes that's the one. I have no idea on how to do that, can you help ?
I can guide you in making the changes yourself, but we're not really in the right place here.
Probably best to continue via PM.
Hi i play mostly videos and on some song i need to move them along to cut out a slow bit ! on vj7 you could do this for the next song on automix but on vj8 you cant ?? is there a way or skin to do this without using both decks ?? Cheers Phil
