I have a herecules console rmx and last week when windows 8.1 came out, it started to give me a bunch of problems. I receive the skin error in the XML. So i deleted the drivers and reinstalled. However I cannot find the software CD. Is there anyway i can get the vdj5 LE software for the Herecules Console Rmx?
Posted Sat 28 Jun 14 @ 12:24 am
If you have the serial number then register it to your profile and simply download the version to that console. Otherwise take a look here https://virtualdj.com/forums/151663/General_Discussion/Lost_Serials_-_VirtualDJ_LE_or_any_other_version.html
Posted Sat 28 Jun 14 @ 1:21 pm
My hercules console works only for a while than I get a message saying I must buy a lances for the control. This new virtual 8 is confusing and sound is never clear at all...
Posted Sun 29 Jun 14 @ 12:57 pm
PC or Mac? What are your sound settings? Are your drivers up to date?
Posted Sun 29 Jun 14 @ 2:51 pm
PC I downloaded latest drivers last week, how is your Virtual 8.1 doing for you and the sound quality?
Posted Sun 29 Jun 14 @ 5:11 pm
never mind
Posted Sun 29 Jun 14 @ 5:17 pm
thats because you have not logged in with your Pro account. On launch a Login window should appear and you will need to use the username (login) and password of your virtualdj.com Pro account. If not, you can do that in Config->Licenses tab as well.
Posted Sun 29 Jun 14 @ 11:33 pm
You will need the serial of the VirtualDJ Le version that came with your controller. Usually its on the sleeve of the LE Disc. If you cant find that, please contact support https://virtualdj.com/team/ for alternatives.
Posted Sun 29 Jun 14 @ 11:35 pm
