All i want is the MAndolane SPI and M3D download.
Trying to fix the Denon MC-6000 problem BUT
I can't find it anywhere because the website does not exist anymore. I have a gig in 4 hours and I am starting to panic.
ANY Guidance or help at all will save my life right now.
THANK YOU ahead of time.
Kirk
Kirk
Posted Fri 27 Jun 14 @ 8:18 pm
*add-on*
if anyone helps me can i just get a simple step by step. I am not to savvy with my lingo and vocab. that goes for mapping, the hardware and software EVERYTHING.
also...all those "I had that same problem too" guys....just shhhhh. let's not flood the forum, making it harder to actually find the person giving direction.
THANK YOU (again)
THANK YOU (again)
Posted Fri 27 Jun 14 @ 8:51 pm
Do you not have a google in your country?
http://mac.softpedia.com/dyn-postdownload.php/8228d52697a1aad102c1dc231ef071b5/53ae2a3c/11e23/4/1
It took me 5 seconds to find.
What more do you need?
https://virtualdj.com/addons/15694/Denon_MC-6000_Full_.html
Posted Fri 27 Jun 14 @ 9:28 pm
It might help if you state exactly what "the Denon MC-6000 problem" is, and what the java software has to do with it.
If it's not related to VDJ software then there won't be much we can do.
You'll have to use your backup kit for the gig.
Posted Sat 28 Jun 14 @ 6:14 am
