Hey guys i bought a pro license 2 weeks ago to run my newly bought mixtrack pro 2 everything was working fine until today, i loaded up both deck as normal and they play fine through the speakers but for some reason i can't get any sound through my headphones to cue up a track on either deck, it just plays the current track through them !!
Posted Fri 27 Jun 14 @ 9:18 am
Have you checked your audio configuration is correct in VDJ?
Posted Fri 27 Jun 14 @ 12:04 pm
sync problem ? i am new to Vdj8 and numark pro2 but was all going ok, then couldnt get deck 1 to sync at all to deck 2, deck 2 would still sync to deck 1 , on computer or mixdeck but pressing the button either on computer or mixdeck on deck 1 would make no change at all to bpm whilst only a few mins earlier it was working fine, had to shut down Vdj and restart it, then it worked, any ideas or have i got aliens causing havok inside my laptop ?! is there something i could of pressed that might of stopped it working or locked my out of deck 1 sync ? thanks
Posted Fri 27 Jun 14 @ 1:00 pm
