Topic: vdj 7 pro vs 8
so i have been trying to use vdj 8 for a little bit now i was haveing a sound isue that i believe was because i was running windows xp i have now upgraded my pc to win 7 and the sound was good for a while but then i got i message about how im only alowed a controlled for tem min then vocals cut out of the pa and i can now only get them in my headphones i was under the understandinf vdj 8 was a free upgrade for people with 7 pro please help thanks. When i put my licance key into vdj 8 it gives me an error saying that is a vdj 7 key?
Posted Mon 16 Jun 14 @ 7:25 am
You need to log in to VDJ 8 before it will allow you full use.
To do this, you need an internet connection. Log in using your forum ID and password.
Once you've logged in, you don't need a connection next time you run VDJ 8 (unless you've logged in to it from another computer since).
