could some one advise me if there is a way to increase the size and colours of the fonts on cue points. Its not too bad on VDJ7 but I have been starting to use VDJ8 today and the cue fonts is very small (it also seems to 'disappear' up into the 'control panal' as per the picture
Many thanks
.Many thanks
Posted Mon 09 Jun 14 @ 11:49 am
It's a skin thing
line 1024 of the 2 deck skin
<group name="waveform" x="369" y="47">
<panel id="defaultwave" group="waveform" visible="yes" >
<rhythmzone mirror="false" upsidedown="false" fade="200">
<pos x="+0" y="+0"/>
<size width="1182" height="92"/>
<colors deck1="#007097" deck2="#8c0709" deck1_active="#009fd2" deck2_active="#cd0f10" />
<rhythm y="+0" height="75"/>
<grid height="6" width="6" maxwidth="10">
<pos y1="+79" y2="+85"/>
</grid>
<cue y="+0" height="92">
<text dx="15" dy="-1" size="14" />
<mask width="12" height="92" x="942" y="1372"/>
</cue>
<overlay>
<size width="2" height="91"/>
<pos x="959" y="47"/>
<background x="1" y="1163"/>
</overlay>
</rhythmzone>
</panel>
Try changing the size on this bit <text dx="15" dy="-1" size="14" />
There might be more to it depending what type of wave you use, but this is very similar to how I did it in V7
</grid>
</cue>
<overlay>
</overlay>
</rhythmzone>
</panel>
Posted Mon 09 Jun 14 @ 5:53 pm
Many thanks for the reply - I managed to find the line in Vdj8 skin code and have increased the size of the font.
Next question is do you (or anyone else) know how I can lower the actual 'Cue Text' down a bit vertically speaking (e.g its in the middle of the wave form zone rather than right at the top of it - hope that makes sense !)
Cheers
Cheers
Posted Mon 09 Jun 14 @ 7:26 pm
Sorry just found how to do the position as well now - adjusted the DY= bit on the same line
Posted Mon 09 Jun 14 @ 7:34 pm
I am searching for Virtual DJ Pro Full
Posted Mon 09 Jun 14 @ 9:04 pm
how can i add effects to vdj8 sample...pls help me tnx!
Posted Mon 09 Jun 14 @ 9:32 pm
Hi Jack! make your own thread.
Posted Mon 09 Jun 14 @ 9:59 pm
