Topic: 1828 or not?
So as I read around the forums I see I am not running build 1828 yet,still on 1820. because I didnt select beta build in the options/config.question is...should I try and let it update to 1828? am I missing out? or would I only get more issues? would it mess up what I have running so far? the things I use in vdj8 seems to be running good.camara works though it needs tweaks and proper order selecting.thats the one I'm afraid to mess up.but would welcome an inprovement...so what's the present status on 1828?
Posted Fri 06 Jun 14 @ 3:30 pm
Tracker only you can answer those questions.
It's a beta, there is a risk that things may not work exactly as they did in a beta build. If you are not prepared to take that risk then don't update it.
if you sign up to get beta build, you still can choose to update or not, after reading the changelog as long as the update window pops up.....might be a compromise.
yeah..maybe its best to leave it alone...and let you guys get the "bullets" in the "front"...
