Hi there,
I am running a virtualdj pro on my Stanton DJC.4 controller with only one problem. I cannot properly control the effects.
The controller has three FX knobs on each side, and an FX selection encoder dial. However, I have remapped the 3rd FX knob to control a VST plugin, "qb_filter". This knob sits at 50%, and controls a high/low pass filter that is a million times better than the standard VDJ filter.
The issue with this is that I cannot use any other FX while the plugin is active, and to deactivate/reactivate every time I want to use an FX is really time-consuming and interrupts my flow considerably. If i do not deactivate the filter, the third slider of the FX i want to use is instantly set to 50%!! - which on the echo is feedback (i think)... you get the picture.
So the question,
Is there a way to change the mapping code to isolate the FX knob to the VST plugin only....
or...
should I buy a new piece of hardware to plugin alongside my controller to control the FX.
If i need a new piece of hardware, please suggest a no frills, USB compatible system.
Thanks for reading
-entwicklung
So the question,
or...
Thanks for reading
-entwicklung
Posted Thu 05 Jun 14 @ 4:47 am
Effect_slider 3 1 should do the job i think...
Posted Thu 05 Jun 14 @ 5:06 am
can you elaborate on that please, im not too good with code mapping.
Posted Thu 05 Jun 14 @ 5:16 am
"effect_slider 3 1" does nothing
Posted Tue 17 Jun 14 @ 4:36 pm
