i use loopout and want to also remove the lows while it loops out...what the mapping for that.
Posted Wed 04 Jun 14 @ 9:30 pm
loop_out & eq_low 0%
like that?
like that?
Posted Thu 05 Jun 14 @ 4:43 am
like that?
like that?
didnt work...
Posted Thu 05 Jun 14 @ 6:39 am
try reversing ...eq_low 0% & loop_out.
Posted Thu 05 Jun 14 @ 12:23 pm
not working either ill just twist the filter knob on mixer
Posted Thu 05 Jun 14 @ 2:17 pm
Maybe the mixer is over riding the eq.
Posted Thu 05 Jun 14 @ 2:42 pm
The eq knobs on my mixer are not mapped to virtual dj, with the mappings you guys suggested either it just loops out or it cuts the low, but its ok ill try a few things if not ill just use the mixers filter. I have a voxoa M70
Posted Thu 05 Jun 14 @ 5:13 pm
is this the loop out effect?
effect 'loop_out' active & eq_low 0%
Posted Thu 05 Jun 14 @ 5:19 pm
this worked used the wrong quote marks i guess. But on thing it doesnt stop the track with the eq cut, it continues on after the effect disengaging
Posted Thu 05 Jun 14 @ 6:14 pm
I don't have my main machine at the moment so can't text this.
I will take a look tomorrow of Saturday and see if can find the solution.
Posted Thu 05 Jun 14 @ 6:24 pm
