Forum: Italian Forum
Topic: Aggiornamento VirtualDj Pro7 con la versione 8
Innanzitutto mi scuso se forse questa discussione e stata già aperta.
Sono in possesso di una licenza Pro7 e vorrei aggiornare alla nuova versione8, come devo fare e se posso visto che ho un Macbook Pro13 ver.10.6.8
Ho già provato ad effettuare una installazione ma nel momento dell'avvio mi da l'ERRORE
Process: VirtualDJ [398]
Path: /Applications/VirtualDJ 8.app/Contents/MacOS/VirtualDJ
Identifier: com.atomixproductions.virtualdj
Version: ??? (???)
Code Type: X86-64 (Native)
Parent Process: launchd [212]
Date/Time: 2014-06-04 12:15:19.551 +0200
OS Version: Mac OS X 10.6.8 (10K549)
Report Version: 6
Interval Since Last Report: 104698 sec
Crashes Since Last Report: 4
Per-App Crashes Since Last Report: 4
Anonymous UUID: 8CF1C55F-BC42-4CB1-83DB-52D2A63E0877
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Crashed Thread: 0
Dyld Error Message:
Library not loaded: /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
Referenced from: /Applications/VirtualDJ 8.app/Contents/MacOS/VirtualDJ
Reason: image not found
Binary Images:
0x7fff5fc00000 - 0x7fff5fc3be0f dyld 132.1 (???) <29DECB19-0193-2575-D838-CF743F0400B2> /usr/lib/dyld
Model: MacBookPro7,1, BootROM MBP71.0039.B0B, 2 processors, Intel Core 2 Duo, 2.4 GHz, 8 GB, SMC 1.62f7
Graphics: NVIDIA GeForce 320M, NVIDIA GeForce 320M, PCI, 256 MB
Memory Module: global_name
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8D), Broadcom BCM43xx 1.0 (5.10.131.42.4)
Bluetooth: Version 2.4.5f3, 2 service, 12 devices, 1 incoming serial ports
Network Service: AirPort, AirPort, en1
Serial ATA Device: TOSHIBA MK1059GSM, 931,51 GB
Serial ATA Device: HL-DT-ST DVDRW GS23N
USB Device: Built-in iSight, 0x05ac (Apple Inc.), 0x8507, 0x24600000 / 2
USB Device: Internal Memory Card Reader, 0x05ac (Apple Inc.), 0x8403, 0x26100000 / 2
USB Device: BRCM2046 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0x06600000 / 4
USB Device: Bluetooth USB Host Controller, 0x05ac (Apple Inc.), 0x8213, 0x06610000 / 7
USB Device: IR Receiver, 0x05ac (Apple Inc.), 0x8242, 0x06500000 / 3
USB Device: Apple Internal Keyboard / Trackpad, 0x05ac (Apple Inc.), 0x0237, 0x06300000 / 2
Grazie per un eventuale Aiuto
Posted Wed 04 Jun 14 @ 5:17 am
Virtualdj 8 è compatibile con osx 10.7 o superiore.
Grazie per avermi risposto, secondo la tua esperienza mi conviene aggiornare il Macbook Pro13 con la versione Maveryck cosi da poter utilizzare il virtualdj8 oppure lascio tutto cosi come stà?
La mia configurazione e
HD da 1TB con 4 partizioni
8 GB di RAM
Grazie
Se vuoi utilizzare Virtualdj 8 , direi che devi procedere con l'aggiornamento a Mavericks
OK Grazie
