Hey guys. Some of my keyboard shortcuts are are not working properly with this new version. How can i map the LEFT SHIFT, CTRL and ALT keys to work separate from those on the RIGHT side? Before they worked LEFT or RIGHT,now they work as one
Posted Tue 27 May 14 @ 9:55 am
Could someone respond to this please?
I'm having the same problem.
Thank you.
Thank you.
Posted Wed 06 Aug 14 @ 4:55 am
This is fixed in the latest beta version.
If you don't get beta builds, but want to, go to the settings and set getBetaBuilds=yes
Posted Wed 06 Aug 14 @ 4:56 am
Thank you so much for the swift response.
I will check that asap.
Posted Wed 06 Aug 14 @ 5:03 am
