well tonight i got to use VDJ8 for the first time in a gig and i had just a couple of issues that i will like to share, the firs one was that when i was playing music and loaded another song i had to adjust the pitch control because it automatically changed the pitch like if i was using the sinc bottom. the second one a couple of times while searching songs on the search bar and hit the letter S the music stopped, i had to press play in my controller to keep playing the song, while playing karaoke i noticed that the screen was not as bright as before using VDJ7 but i found out that the fader and volume sliders had to do with that so i disabled the fader and volume so i could get the right screen brightness. besides that the night went smoothly and i got compliments about how good the system sounded. even thou i have a VMS4 and is known that this controller does not have the best sound card out-there. all i know is that VDJ8 is awesome and i just need to configure it so i get it working the way i want it. any tips are welcome on how to fix this small shortcomings
Posted Sat 24 May 14 @ 2:58 am
Configuration, reset pitch on load, or something to that affect. Controllers, keyboard, I delete any letter that does something. S is stop, andP is pause. There are others, so pick the ones that you want.
Posted Sat 24 May 14 @ 3:13 am
The config option is autobpmmatch - needs to be off.
When it changed the pitch, did it just suddenly start doing that out of the blue? I had that myself once.
Posted Sat 24 May 14 @ 5:05 am
well i already figured out that to make it work like vd7 you have to turn off the above mention things. but i am very happy is working fine so far thanks guys
Posted Mon 26 May 14 @ 4:55 pm
Awesome to hear!!
Posted Mon 26 May 14 @ 6:26 pm
You can set the keyboard to disable in the controller settings so that while your typing you won't stop the track or play a sample etc.
Posted Mon 26 May 14 @ 7:47 pm
