Is the a way to change the color of the jog wheels back to white.
Posted Fri 10 Aug 18 @ 9:56 am
yes thats easy LOL just click on the (Skin Tab) top right corner & click platter color
Posted Sat 11 Aug 18 @ 5:08 am
That was easy lol thanks
Posted Sun 12 Aug 18 @ 1:35 pm
there is a bug on mac. I'm using vdj 2018 (also happened on vdj8) on High Sierra (also happened on Yosemite).
when using this skin (which is graphically wonderful, thanks!) if there are cue points set, I can no longer jump to any part on the waveform using the mouse/trackpad. there is something, like a label, that appears with each cue point and blocks the waveform.
Posted Mon 13 Aug 18 @ 7:36 pm
Anyone have ANY IDEA why you can't click the waveforms? It works 100% on the default skin, but not dennyo.
Posted Sat 20 Oct 18 @ 4:22 am
Bump
Posted Mon 22 Oct 18 @ 2:08 am
Bump again!! Is this skin not updated anymore?
Posted Sun 09 Dec 18 @ 5:06 am
The answer was provided in the other thread where you posted exactly the same question.
Posted Sun 09 Dec 18 @ 8:07 am
Hi Bertie,
You must deactivate SongposLine in the Skin options.
Posted Sun 09 Dec 18 @ 8:59 am
On the non HD version of the skin is there anyway to toggle the effects to have 3 efx instead of 1?
Posted Sun 09 Dec 18 @ 5:47 pm
skin 4 error .... please
Posted Fri 18 Jan 19 @ 12:45 am
Hi , how can i change mixer color effects ? thanks gretat skin !!!
Posted Sun 20 Jan 19 @ 9:48 pm
friend greetings from Ecuador ... skin 4 is not activated ... what can be the error?
Posted Fri 25 Jan 19 @ 8:20 pm
Hello community,
some guys questet me for an update to 2020. I work in this moment for an Update. I think it comes on the middle of january.
Best regards DennYo
Best regards DennYo
Posted Sun 29 Dec 19 @ 12:24 pm
Hello all,
the upgrade version 3.0.0. has been uploaded and is waiting for approval by VDJ.
http://www.virtualdj.com/plugins/index.html?addonid=81086
best regards DennYo
best regards DennYo
Posted Mon 16 Mar 20 @ 10:11 pm
I'm looking forward to using your updated version Dennyo :)
Posted Mon 16 Mar 20 @ 11:10 pm
Thanks for The Nice Skin
Posted Tue 07 Apr 20 @ 10:00 pm
