I am running Virtual DJ 7.4 with my Pionneer DDJ-SX Controller . So last night I had a song playing on the left deck , and I had a song on the right deck loaded . I noticed that everything on the right deck was frozen and nothing was working , I event Tried spinning the jog wheel , which did fast forward the song but when I hit play nothing happened , even the slicer , sample , hot cue all those buttons were not responding . The song on the left deck was running out of time so I decided to get on the Mix and announce the cake cutting , so I then turned off the controller and Vj and turned it back on , the rest of the night was fine . Any idea of what happened /
Posted Sun 18 May 14 @ 12:31 pm
not sure on an answer to your problem but I have also had issues recently with my sx and playing certain decks. the solution I found that seems to work for me is to have a 4 deck skin and make sure all the input selectors are on PC for the channels you want to use also make sure you don't have dual deck on
Hope that helps !
Hope that helps !
Posted Sun 18 May 14 @ 2:06 pm
