I ad the drive to search in vdj but not all of it shows up. I. An go to just the drive and find it so I know it's all there. Just need to know how I can fix this
Thanks
Thanks
Posted Sun 18 May 14 @ 10:06 am
which kind of files are not being found in vdj ?
Posted Sun 18 May 14 @ 10:33 am
I have music video and karaoke
Posted Sun 18 May 14 @ 10:51 am
did you activate show video and karaoke in the browser_option menue? ( little round button left below in the vdj browser window)
Posted Sun 18 May 14 @ 11:20 am
yep. someone told me that you can only put so much music in a folder if you put to much in the folder it will not show all the music in the search is this tru
Posted Sun 18 May 14 @ 12:10 pm
You can put as much music as you like into a folder. It will only not show in search if you haven't added it to your database yet.
Please see https://virtualdj.com/wiki/Add%20to%20search%20DB.html
NOTE: It's generally a good idea to organise your music into a sensible structure, such as Year\Genre
Posted Sun 18 May 14 @ 5:02 pm
Thanks for all the info i will try it out.
Posted Sun 18 May 14 @ 5:47 pm
Just on the back of that..... You know how in VDJ 7 you where able to find out how many Songs / Videos / Karaoke files you had loaded into the VDJ database is there a way
to show this in VDJ 8
Posted Mon 19 May 14 @ 4:03 pm
Just search for * to get a total ammount of titles.
If you need it seperated by the type you could create filter folders for the filetype (audio, video, karaoke) and check there for total number of files.
Greets, Heiko
Greets, Heiko
Posted Tue 20 May 14 @ 12:05 am
