I was trying to set my vdj to one button chop in the process I messed everything up,my left deck plays with crossfader all the way to the right and right deck with crossfader all the way left. I went to reset to default but still the samething.ive been trying to correct this for over 2hrs so I really need the help thanks .This is for the vdj 7 pro home. If anyone knows how I can change it to one button chop could you share this with me.i know how to use the two tables but just want on button cause its easier. thanks!
Posted Thu 15 May 14 @ 10:31 pm
Anyone with any ideas? thanks
Posted Thu 15 May 14 @ 11:41 pm
Check in settings for cross fader hamster (inverted)
You should register your pro license on the site and then you can try a pre-release of version 8.
Posted Thu 15 May 14 @ 11:59 pm
thank you djtouchdan,that was it.i don't know how to register I just downloaded it for free,i just have it cause I like to pass time with it im not trying to do anything serious with it. Now do you know how to make my chops one key? I have a friend that has his set as the space bar, but it is a older version. Like I said I know how to use the crossfader with 2 decks im just looking for a easier way and that beat grid is trash.Thanks again
Posted Fri 16 May 14 @ 12:12 am
If you downloaded a Pro version for free then you have almost certainly done so illegally.
If you like the software then please support it and its future development buy purchases a license or alternatively there is a new subscription service.
https://virtualdj.com/buy/
Posted Fri 16 May 14 @ 12:33 am
He said "VDJ Pro Home".......
He probably has the free version.
Posted Fri 16 May 14 @ 4:11 am
Actually there is only a Pro Full which cannot be licenced any more ( only upgrade to Pro Full or buy Pro Infinity) and a Home Free. There is no Pro Home...;-)
Just want to be shure we talk about the same version...;-)
Posted Fri 16 May 14 @ 4:18 am
I know there's no Pro Home - he probably added the "Pro" himself!
Posted Fri 16 May 14 @ 4:46 am
Yep, i sit corrected.
Its was late or was it early? I don't know!!
Posted Fri 16 May 14 @ 5:22 am
I've been up late/early recently a lot too. I wonder why??????
I close my eyes at night and see eights everywhere.....
Posted Fri 16 May 14 @ 11:13 am
it is the free home version...
Posted Fri 16 May 14 @ 1:22 pm
Not yet.....
Posted Fri 16 May 14 @ 1:33 pm
I can't get any sound out of my speakers. Was using Virtual DJ LE and possibly did the pro trial which ended early. Everything was fine and now I have no sound and I have a gig tonight.
Posted Fri 16 May 14 @ 1:48 pm
so the one I have is illegal?
Posted Fri 16 May 14 @ 1:58 pm
I dunno why Dan said "not yet". If you have the free home version then that's fine.
Posted Fri 16 May 14 @ 2:16 pm
well it says its free.?
Posted Fri 16 May 14 @ 2:25 pm
7.4.1 is Free to download - yes.
There will be a free version of 8 when it gets officially released.
Posted Fri 16 May 14 @ 2:28 pm
