Topic: [NEWS] VirtualDJ 8 Pre-Release - Page: 6
can some one help ive got new virtual dj 8, don't mean to be thick, but how do you make playlists
Please do not post the same message in multiple locations. It's against the forum rules.
the great thing is reading the manual shows you a lot. I set the manual on one screen and vdj 8 on another, so i can get used to it. there is so much to this new program, I know i don't want to miss anything.
getting the logo off is in config, video then click on advanced and say no to logo..
Okay take one of your playlist and drag it over to the right of your screen , where you can open the sideview , drag the playlist folder into there . now take a song a drag it anywhere you want , it automatically saves .
Thanks to the team of VDJ for the realization of Virtual DJ 8. Done a great job, well done guys. Everything works fine on my laptop.
hi guys, my question is, because my hercules rmx, does not work or is not control any buttons or jogwheel, only shows me the audio outputs but with a red x at the end, please help
PLEASE PLEASE PLEASE
Can technical questions regarding the Pre-Release of Virtual DJ 8 be reported in here : https://virtualdj.com/forums/75/VirtualDJ_8_Pre-Release_Forum.html
We have the beta testers regularly checking the forums to assist as well as the development team picking up on issues. Having posts everywhere is confusing.
Thanks for understanding. :-)
awesome.
groovindj wrote :
Change the sampler layout to list view, then click the edit button (gear icon).
There's no way of switching them directly (from either mode/view) like there was in V7.
Thanks, I figured it out about an hour after posting my question, lol! and you can input way more than you ever could with clip bank this way. I gotta say, I'm kinda lovin VDJ8 so far!
cnt wiat for this to release,just which the word size were a little bit bigger
On the bottom left hand corner there are 2 buttons to enlarge or shrink the text
Nice job Atomix team...looking forward to giving it a go.
Thank you VDJ Team. Nice look and I will definitely check it out. FLeX
How do I make SONIQUE trans from one to another on audio file only?
Check out the owners manual that installed with the program.
The option is videoaudioonlyvisualisation, I believe it's an advanced option.
Thanks God
has anybody try virtual dj 8 with timecode record i try it but i have numark virtual vinyl pro and it only give me ten min to play with it .there a delay for the ten min i play with it i like to scratch i guess i have to wait to upgrade to virtual dj 8 infinity can anybody let me know if there are setting to make the scratch tighter
Make shure that you have the necessary directX9 drivers installed and set sonique as plugin for videoAudioOnlyVisualisation in options
Infinity would be what your using. It's just pre-release. There is some timecode talk here:
https://virtualdj.com/forums/187224/VirtualDJ_8_Pre-Release_Forum/Timecode_users_________.html
I'm using it with CDJ's and the response is great. I don't have the ability to scratch, so I cannot comment on drift and tightness myself.
64%
