If you have a legal licence you can register it here to get the update for free :
https://virtualdj.com/users/edit.html
Posted Sun 11 May 14 @ 5:08 pm
Please provide more information.
Posted Sun 11 May 14 @ 5:09 pm
ok i have numark cue ...... so do i have to upgrade to use vdj8
Posted Sun 11 May 14 @ 5:11 pm
Cheers!
Posted Sun 11 May 14 @ 5:14 pm
In the past, Numark CUE was updated after Numark had a chance to check, test, and inspect the software to their liking. I do not know if that will be the case moving forward but, historically, that is the way it was handled.
Posted Sun 11 May 14 @ 5:20 pm
Is there a place to find the new mappers for VDJ8? I'm having issues with the NS6, which (obviously) I didn't have before. Also, is there an Android tablet app for controlling like the Apple one? It seems kinda silly not have one but I can't find one.
Posted Sun 11 May 14 @ 5:25 pm
Is there no Cue crossgrade any more?
Posted Sun 11 May 14 @ 5:31 pm
seems that there be no x-grades at all
Posted Sun 11 May 14 @ 5:33 pm
Did you look to see if there was a crossgrade from Cue to VDJ 7.4?? If so I believe you can do that, then be eligible for 8.. Just throwin the idea out there.
Posted Sun 11 May 14 @ 5:47 pm
I know it used to be possible because there are forum posts which mention it.
Posted Sun 11 May 14 @ 5:54 pm
So where is the V8 user guide?
Posted Sun 11 May 14 @ 6:24 pm
If you've installed 8, it's in the same location as your V7 manuals.
Posted Sun 11 May 14 @ 6:25 pm
/MyDocuments/VirtualDJ/
Posted Sun 11 May 14 @ 6:32 pm
Perhaps a link to the PDFs via the config would be a good idea.
Posted Sun 11 May 14 @ 6:41 pm
First Impression: YISSSSSSSSSSSSSS :D
Posted Sun 11 May 14 @ 7:13 pm
Anyone figure out how to remove the Logo of VDJ when doing video. LOve VDJ but hey I like the new spinning logo options also!
Posted Sun 11 May 14 @ 7:34 pm
Guys, any idea as to why the volume meter on SR is not working?
Posted Sun 11 May 14 @ 7:45 pm
in options, turn on advanced (check box right corner) and search for "logo" ;)
Posted Sun 11 May 14 @ 7:50 pm
thanks guys for the preview release
Posted Sun 11 May 14 @ 8:24 pm
any way to disable limiter
Posted Sun 11 May 14 @ 8:26 pm
