I'm having a problem on either deck when I change Pitch Bend the sound will be distorted. I have used in the past no problems
THX DJMA
THX DJMA
Posted Sun 27 Apr 14 @ 11:06 am
What is your setup? Are you changing the pitch bend on your decks or VDJ itself?
Posted Sun 27 Apr 14 @ 11:57 am
Using Lanovo i7 laptop with DN MC 6000 Midi controller windows 8
changing pitch with controller
Posted Sun 27 Apr 14 @ 12:31 pm
I would try and reset your mappers, and switch over to a different skin to see if that makes a difference. Also have you tried adjusting the pitch bend meter in the VDJ configurations? I had a similar problem and it was due to my pitch bend meter being too far down in the configurations, thus when I turned the pitch bend back up it fixed the problem.
Posted Sun 27 Apr 14 @ 12:53 pm
I'll give that a go THX
Posted Sun 27 Apr 14 @ 12:57 pm
The pitch bend buttons, or the pitch adjust sliders?
Posted Sun 27 Apr 14 @ 4:56 pm
Sliders
Posted Sun 27 Apr 14 @ 5:13 pm
Ah, I thought you were talking about the pitch bend buttons. In that case I don't know sorry.
Posted Mon 28 Apr 14 @ 5:14 pm
What happens, if you move the sliders, in the software?
Posted Tue 29 Apr 14 @ 4:05 am
Sound distortion either side
Posted Tue 29 Apr 14 @ 5:59 am
Geez, you either stay up longer than I do, or get up really early. I'm trying to remove as many variables, as I can. Remove the controller, from you machine. If you move the sliders with your mouse, It still makes noise?
Posted Tue 29 Apr 14 @ 5:52 pm
This problem happens at my shows with controller I will check without controller on FRI my next day off
Posted Tue 29 Apr 14 @ 6:10 pm
The time is only 7p not what the time this gets posted FYI
Posted Tue 29 Apr 14 @ 6:11 pm
I was talking about your post at 6:59am.
Posted Tue 29 Apr 14 @ 6:17 pm
Hmm I do some crazy hrs but that's the DJ life
Posted Tue 29 Apr 14 @ 6:26 pm
I think I figured it out
Under Performance tab bottom right 48khz conversion
Was set as quality resampling change to fast resampling and
It's fixed
It's fixed
Posted Wed 30 Apr 14 @ 11:12 am
