Topic: Can someone help me please
Posted Tue 22 Apr 14 @ 7:46 pm
(youtube)video id(/youtube) (CHANGE ROUND BRACKETS TO SQUARE BRACKETS)
video id = https://www.youtube.com/watch?v=87UDaBGpijs&feature=youtu.be
I'll let one of the timecode experts answer the issue though. :-s
Never saw this befor :-/
What was the error message @3:42 saying?
the error is not the problem that come from a bad skin
Interesting, I had the oposit problem when I was using my Roland Duo for input from my CDJ1000 with Serato CD's. The track would keep increasing in pitch. I cannot remember if I was using it in ASIO or WDM at the time. I did not keep troubleshooting it because I switched to an Audio 6 interface. Since then I have not had the issue.
Does it do it in all modes, relative, absolute? Are you getting dropouts in your ASIO feed?
What components do you use? TTs and soundcard?
I just reread a little in the german forum. There was a user who described the same behaviour.
He used a ESI Maya 44 USB soundcard.
After changing to another one that never happend.
Working for my without issue at this time. Serato CD - Pioneer CDJ 1000 mk1 - Pioneer DJM 600 - Traktor Audio 6 - Anker USB3 Hub - Toshiba Satellite with Win 7. There is a little more detail in the PC specs in my profile.
The only component that changed was from the Roland Duo to the Audio 6. I also have a CDJ 400 in the kit, but it is just used as a controller for another deck, not timecode. The audio for that third deck goes through the Audio 6.
A quick search brought up this post. Might be worth a check.
I use a voxoa m70...but I've had this problem before with and a sl1...and my Hercules djtrim. I have not used time code since I had a controller but want to play and get back to the core of djing...and if u don't know what turntables those are then u will be no help.....but it's not the 1200s causing the problem....I'll reload the Asio driver and see if that helps
@ ratedXXX. Where did you get the Voxoa Mixer from. The M70 looks like a Rane 68. Nice.
From nimbus at www.teknowdj.com 439. Plus shipping...and I love it...except for this problem
I'll try but I'm sure I've tried it both ways.....Also I turned the pitch sensitivity up to the max it seems to be holding tho it looks like it is still trying to change....but I'll check when I get home
