Topic: How best to search entire library in VDJ?
Hey guys, my library is structured like most folks system [dance, pop, rock, reggae e.t.c]. If I wish to search for a song but don't know if or in which particular folder or category that song is located, is there any way to search my entire library in VDJ please?
Posted Tue 01 Apr 14 @ 5:06 pm
You'll need to register your license.
Check out the FAQ, specifically here:
https://virtualdj.com/wiki/Add%20to%20search%20DB.html
Make sure you have added all of your folders. Then things should come up in the browser search.
You shouldn't need to register for that. If you have a serial number for say LE or Pro for example, I recommend registering to get updates and such.
Works, thank you very much!
