even when the pitch is just a couple of BPM away from zero
i can hear a significant reduction in the sound quality
the sound is kind of "warbly"
even a friend of mine who would not normally notice these sort of things noticed it
is there a way to fix this?
Posted Thu 20 Mar 14 @ 3:58 am
Change in BPM isn't the variable you mean, how much does it work out in pitch%? I notice at about 4%, Check if is Master tempo is on advanced config>performance>Master tempo
Posted Thu 20 Mar 14 @ 4:17 am
The following article might be of interest to help you understand why this is hapenning:
http://www.djtechtools.com/2014/03/16/keylock-in-dj-softwares-compared-serato-dj-traktor-pro-virtual-dj/
Posted Thu 20 Mar 14 @ 7:18 am
Best results can be achieved with Master tempo Engine set to Advanced (Config->Performance tab)
Posted Thu 20 Mar 14 @ 2:08 pm
