Topic: cue points and Automix
Is it possible to set Automix up so that it mixes at Cue points rather than intro. Looking to use Automix to run a Karaoke list and want to set it up to the song starts.
Cheers
Daz
Posted Mon 10 Mar 14 @ 12:53 am
Rightklick at the bpm button in your decks. window "adjust bmp values" is popping up. choose edit automix....
Yeah, but the automix points are not the cue points.
This has been raised before.
People have asked why VDJ can't use the existing cue points, because many people set/use cue points in their tracks for other purposes, and it would make sense for automix to use them.
It's a pain to have to go through every track and set mix points too. Why is there no choice between using the cue points or setting automix points?
Thanks for the info.
Agreed Groovin. It's a bit of a clunky process. At least it gives options for different types of mix tho. Quite like that :-)
Daz
