hi guys, i know this might sound silly but i need help on a simple thing.
the track is playing on side A and i want side B to be playing in my headphones. i tried a few things and doesnt seem to be working for me. it is either the song playing in the speakers in my headphone also or nothing at all. meaning side a plays in speakers but i want side b to be playing in my headphones so i can mix
i know it may be silly and something obvious but please help. thanks
Posted Mon 24 Feb 14 @ 9:11 am
Are you using any external sound cards or mixer is probably the first question, the next, have you checked your settings in > config > sound setup
Posted Mon 24 Feb 14 @ 9:24 am
Details of how you've wired up will help us help you.
Posted Mon 24 Feb 14 @ 9:44 am
i have my laptop connected to my numark idj3
and that is connected to an spl2000 amp with 3 speakers
i have not used it for around half a year and getting back into it today
the headphones worked fine before, meaning played side A via speakers and side B in headphones
with my idj3 i got a virtual pro cd with that. however before i started today i updated the software to virtual dj pro. so could it be a setting that needs changing??
thanks guys
thanks guys
Posted Mon 24 Feb 14 @ 10:18 am
Posted Mon 24 Feb 14 @ 10:32 am
can someone please help me with the firmware update. i have no clue when it comes to stuff like this. i followed the pdf file and got up to the bit where it says it will erase firmware. then after downloading midio - ox, i am just lost and have no idea what to do and tried over again and now my decks doesnt play :(
Please help me anyone and put me through the stages of how to get it back working again
again i am no good with stuff like this annd need alot of help please
Posted Tue 25 Feb 14 @ 10:26 am
you need an LE version of the software for your controller or the Pro version (registered)
Posted Tue 25 Feb 14 @ 11:01 am
hi again, ok i go through update firmware routine. i hold stutter and sync whilst plugging to illuminate both cues
i then press then.
when i go to send firmware, they flash for a bit then stops and says,
sysex: no buffers available: there is not enough memory for this task.
someone please help :( i am under pressure and need this to work by friday as i have a gig then. plzzzzzzzzz
i then press then.
Posted Wed 26 Feb 14 @ 10:09 am
Contact Numark.
Posted Wed 26 Feb 14 @ 10:33 am
Hi,
I have American Audio vms 4.1 and i am using virtual dj LE and everytime i open virtual dj and go into config in sound setup the outputs wont save as external mixer. When a track is playing the crossfader is working and the jog and stuff but there is no sound coming from the amp. can anyone help me please.
Posted Sat 24 May 14 @ 12:55 pm
Please do not hijack someone else thread. In the future, start you own thread, this way all info will be about your issue. Please check here.
Posted Sat 24 May 14 @ 11:03 pm
