FIRST: im Mac OSX user.
I start a topic in Beatunes Forum because i cant drag and drop songs from that software to virtual dj. After tests we realize that only virtual dj dont do this.
I teste drag and drop from beatunes to itunes, traktor and vlc and it works.
The Beatunes Creater send this message in forum:
"Drag and drop is all about data flavors and what one application export and another is capable of importing.
In this case, it seems to be like this is a VirtualDJ problem (because other apps seem to work fine). Have you perhaps contacted them about this?
Thanks,
-hendrik
Thanks,
-hendrik
Posted Thu 13 Feb 14 @ 10:05 am
VDJ has its own library. Once you've imported your songs to VDJ, there's no need to use any other library software.
Posted Thu 13 Feb 14 @ 10:28 am
thanks for aswer..
i know that virtual dj use your own library, but in this case i want the possibility to use togheter with finder, for exemple ( thats works), and from itunes ( thats works too)
i know..
if i try to drag and drop from itunes to virtual dj..its works
so i wonder to use this tip in beatunes too.
i know..
Posted Thu 13 Feb 14 @ 10:45 am
