I have everything hooked up correct (at least I'm pretty sure) & I have the correct settings. But when I click on timecode it says silence it doesn't even have any % With at all.
Hopefully somebody can help me out.
Posted Thu 06 Feb 14 @ 9:21 pm
You need the full pro version to run timecoded vinyl
https://virtualdj.com/products/comparison.html
Posted Fri 07 Feb 14 @ 6:14 am
I do have the full pro version.
Since I only had 1 turntable hooked because the other is broke I selected single timecodes. external mixer, & the ASIO driver.
And earlier this morning I decided to try selecting 2 timecodes & this time the quality was jumping around 100% Now it's around about 1-3%.
What can I do?
What can I do?
Posted Fri 07 Feb 14 @ 10:47 am
Which version of Pro Full are you using ? (version number and build)
Greets, Heiko
Greets, Heiko
Posted Fri 07 Feb 14 @ 11:35 am
Please register your software on the forum.
1. It gives you access to all available updates/soud effects
2. You can't ever lose your serial
Also some more info would be great..
wich timecode records are you using?
did you split the signal or did you hook it up for timecode only?
wich needles?
wich needles?
Posted Fri 07 Feb 14 @ 11:36 am
I have version 7.
And I'm using Scratch Liver Control Vinyl & I have a Numark CC-1 or something similar to that.
Posted Fri 07 Feb 14 @ 1:51 pm
I hate to be rude, but I also hate to help ppl who download torrents..
Not accusing you of anything but I guess you'll get more help after registering your software
btw, last version is 7.4.1
Das
ps I'm running tcv on maya also ;)
Das
Posted Fri 07 Feb 14 @ 2:02 pm
