Hello sorry if this has be answered before, but I just got my system almost back to Normal was up tell 3 am last night... so I am a bit tired
I just have one issue with the PFL knob and 2 buttons
This is a Clean new install of VDJ Pro 7 Full, my new issue is Why dose the PFL (headphone) follow the Crossfader ? lol should it be the other way round? I think my pfl is inverted!
I had the pfl set up, so I could monitor the in coming track say Deck "A", While "Deck B" is playing on the Loud Speakers.
in my headphones, I could monitor deck B, or A or both and do all the fiddling pre cueing rewind and all that jazz...
Or push whatever pfl button to pre hear the incoming track from whatever deck and use the "Pre-Cue" knob my my Hercules 4-Mx Controller to slide from Deck "A" to "B" or anything in-between Via headphone pre cue knob only.
Now, when I and mix, and use the pfl (headphones only), it monitors the same deck as what is being Played and follows the Crossfader (LOL)
I did a search for PFL on the Forums and returned the following
Search results for PFL
No result found...
back to my laptop, under Config>Settings>Mappers>PFL the Greek code is as follows:
pfl & deck left wheel_mode "browser" while_pressed & deck right wheel_mode "browser" while_pressed
I wont to be able to monitor the current track playing and the on coming pfl for the other Deck via the rotatable knob and or pfl buttons
so i can mix again please help, anyone have the code for this?
Posted Mon 03 Feb 14 @ 8:06 pm
3 things you need to check/verify..
1. Hercules Drivers are installed properly
2. PFL MIX knob of 4-MX is all the way to the left (Headhones Mix)
3. Sound Setup is as followed..
Inputs : None (or Microphone)
Outputs : Headphones (Master: Chan 1&2 / Headphones: Chan 3&4)
Sound Card : ASIO .. Hercules ASIO from the menu
Posted Mon 03 Feb 14 @ 10:28 pm
Thank you !!!!!!!!!!!! this was going to be a big ass long post lol
was typing out all the config screens by hand lol got down to Advanced config and was reading them off then it hit me like a lead weight
I over looked the "Head phone ch" in the DJ Console was set to "1&2" and i just changed it to "3&4" now all is SCREAMING!
thanks man !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
thats all it took (y)
Posted Mon 03 Feb 14 @ 10:45 pm
