I HAVE 2X DENON 3700 ,,, DDM400 MIXER AND IM TRYING TO FIND THE RIGHT WAY TO SET IT UP AND IF IT IS POSSIBLE TO USE THE 4 DECK MIXING .....MY PROGRAM WORKS FINE .... MY DENONS ARE LITE UP IN THE MIDI MODE MY CHANNELS ARE SET TO MIDI 1 ON MY 3700, I SEE THE TWO DECK IN THE DENON ASIO DRIVE AND ITS UPDATED IM USING THE DENON ASIO DRIVER AS MY SOUND CARD FOR VIRTUAL DJ AND IM PLUGGED IN GOOD ... 2 DECK MIXING IS OK BUT IM LOOKING FOR MORE EXSPRESSION WITH THOSE 4 DECKS CAN SOMEONE HELP ME OUT
Posted Sat 25 Jan 14 @ 5:21 pm
I think you need VDJ Pro... You have a limited edition...
Posted Sat 25 Jan 14 @ 6:13 pm
THANKS I HAVE PRO FULL VERSION
Posted Sat 25 Jan 14 @ 6:34 pm
Please do not type in all caps.
If you have VDJ Pro then please register the serial number to your account.
Posted Sat 25 Jan 14 @ 7:00 pm
my bad sorry i shouldnt type all capitals my bad and when it comes to the registering part of it well my ex-woman bought this program for me so i really dont know the serial number to register it now but its on my pc..... i have the vdj pro full on my pc but its registered in her name and i dont get down with her anymore its hell being a dj... but anyway what iam doing now is i went to the advance config and i this is what i have
deck 1 denon dj asio driver (ASIO) output 3&4
deck 2 denon dj asio driver (ASIO) output 1&2
deck 3 Speaker And HeadPhone (IDT High Definition Aduido CODEC)
deck 4 ..... well i havent even touched it yet
I hear poping sound and crackling when im using deck 3 ,,, i only use deck 3 to play instrumentals at a 8 count loop so i'm looping and drop my beat in on the loop side of deck 3 i usually lett my instrumental play for about 5 songs and drop in another instrumental on deck 3 ,and when i drop it in on deck 3 theres no crackling
when i goto the configure screen
and i press on performance to check everything ou this is what i have ....
Latency(2048)
safe mode box isnt checked
Scratch is optimized for quality
Master tempo is Fast Strectching
Memory is set to 60 mn
Skin resizing is set to fast resizing
any help would be appreciated
Thanks DJOK
Latency(2048)
Thanks DJOK
Posted Sat 25 Jan 14 @ 7:34 pm
Contact support and I'm sure they'll be able to help with transferring the serial number.
https://virtualdj.com/contact/
Cheers,
Roy
Cheers,
Roy
Posted Sun 26 Jan 14 @ 4:36 am
