Topic: Static noise over hedphones
This morning I turned on my system for a practice set, and I noticed a static noise coming out of my headphones through my mixer. I'm using the Behringer DJX900, and I had experienced this static noise in the past but only when using my laptop and running virtual DJ. This morning, I had nothing but my mixer and my two CDJ's hooked up to it, and that's when I noticed the static noise.
Any ideas as to what might be causing such static noise?
Again, I only have my two Gemini CDJ700 units and the mixer, Behringer DJX900, hooked up. I also switched headphones to see if it was maybe my cans, but nop.
Posted Sat 18 Jan 14 @ 5:20 pm
...and when I'm not running my computer?
And when you think you have found the problem unit...try reversing the plug (reverse polarity) while everything its plugged they way you will use it...ran into something like this as I added yet one ome guitar pedal to my 10+ pedal system..all running on power supplies.
