So i use 2x reloop 2000mk3 tt's that are hooked up to Hercules RMX on the tt's i have Native Instruments TRAKTOR CONTROL VINYL MK2 everything is connected correctly. But the problem is when i put on a song the bpm goes wild and the song its kinda speedup when i go to config virtual dj reads the signal but it isnt circle shaped its like a bigger point My question is what is the problem did anyone expirence it? Is it the vv thats not supported by vdj or something else Please help ASAP
Posted Sat 28 Dec 13 @ 1:15 pm
Time code only works with full Pro version, not the LE version you have.
Posted Sun 29 Dec 13 @ 12:56 pm
Unless hes using the trial version.....
@Djbassjack3r, can you post a picture of the timecode setup screen?
Posted Sun 29 Dec 13 @ 1:15 pm
As i remember - the Traktor V2 Vinyl is not supported.
Posted Sun 29 Dec 13 @ 1:34 pm
I have full version.. I got seemed it to work but the bpm problem is still there and the quality is horrible 5% of 100% only.. tmrw ill upload the pic of it
Posted Mon 30 Dec 13 @ 4:45 pm
The new Traktor signal is different to the old one - this is why it is not working i think.
Greets, Heiko
Greets, Heiko
Posted Tue 31 Dec 13 @ 1:12 am
