Hey I just receive my wego 2 and yes I know u control which deck u hear through the earphones by pressing one of the 2 "cue" buttons n play with the earphone volume ... But when I do this there is no difference I what I hear through my earphones...
Am I crazy or arent i supposed to be able to listen to one song playing on one deck trough my earphones and a different song through my speakers?
Thanks
Thanks
Posted Sat 28 Dec 13 @ 9:40 am
Yes, you just need to set everything up correctly. Read the manuals and follow the instructions.
Posted Sat 28 Dec 13 @ 11:21 am
I did Thats what i dont get. In the manual it says press the cue button and headphones will monitor that deck but it doesn't...
Posted Sat 28 Dec 13 @ 1:56 pm
You need to set the sound config correctly.
This should be in the manual, but it's also detailed here.
Posted Sat 28 Dec 13 @ 2:08 pm
The Wego only works with the LE version of the software, that came with it, or the Pro version. Please install and register the version that came with the controller.
Posted Sun 29 Dec 13 @ 12:52 pm
