Topic: Virtual DJ 7.02 with CNTRL-2 controller
Installed software that came with controller but I'm loosing headphone audio after about what appears to be 10 mins or so. Works fine after reboot for another 10 mins or so... Any ideas?? Thanks in advance
Leighton
Posted Tue 17 Dec 13 @ 11:43 am
Not sure why you have such an old version of the software. Did you buy this new? I know some functions have a ten minute time limit. I'm sure someone with more knowledge about this controller will be here to help you.
Are you losing Midi control as well , after 10 minutes ?
Seems like you are using the Home Free version instead of the LE version that came with your controller.
Im using the software that came with the controller when i bought it. The software is... virtualdj_le_gemini_v7.0.2. i dont loose midi control but only headphones.
Thanks for the reply
