Topic: Audio 2 DJ Soundcard
I'm trying to setup this soundcard but can't figure out what's wrong. It seems like virtual dj is not recognizing the card as I can't select it as one of the sound cards. Anybody else using this card?
Posted Mon 09 Dec 13 @ 3:17 pm
Windows or Mac ? Have you installed the proper drivers from NI webpage ?
I use an AUDIO2 occasionally - installed drivers and then selected as an ASIO device, configured latency in it's control panel and sorted :)
I use this as part of my regular setup.Make sure you have the latest drivers and select Asio output and as the previous post stated,you should be good to go. I have no issues using it on an HP Windows 7 P.C.
make sure it's not plug into the usb3.
Mac. I'll look at the NI page for the drivers, although now i'm thinking it could be the soundcard. When I plug it into my usb port the card lights up for a couple seconds then it goes off. Shouldn't it stay on the whole time?
Nevermind, the updated drivers worked. Thanks!
