Hello
On one of my my controllers I have the new loop_roll effect mapped to a few buttons, and it works great
But on another controller I am running out of buttons, and only have a knob to spare
Is it possibly to map loop_roll to a knob, so it starts when the knob is turned, and gets progressively shorter when the knob is turned further?
In that case, can anybody provide the script for such a functionality?
Best regards
Klaus Mogensen
Best regards
Klaus Mogensen
Posted Fri 15 Nov 13 @ 4:18 am
try something like
param_greater 0% ? loop_roll 1 & param_smaller 20.00% ? loop_select 1 : param_smaller 40.00% ? loop_select 0.75 : param_smaller 60.00% ? loop_select 0.5 : param_smaller 80.00% ? loop_select 0.25 : param_smaller 100.00% ? loop_select 0.125 : loop_select 0.625 : loop_roll 0
Posted Fri 15 Nov 13 @ 7:03 am
synthet1c wrote :
try something like
Thanks. I'll try it tonight :)
Best regards
Klaus Mogensen
Posted Fri 15 Nov 13 @ 8:47 am
