http://www.ustream.tv/channel/truelifesound-oooowwaaahhh-dj-show
do you here that poppimg how do i get that to stop....it happens when im cueing the inactive deck. i was just playing around trying to find out why. i have set all latencies and no matter what i get those pops. hp amd 64 x2, 4gb Ram. any ideas?
Posted Wed 13 Nov 13 @ 10:36 pm
Sounds like it's poppin on the bass. Could be your speakers, or you might be peaking your levels somewhere. Have you run dpc latency checker on your computer? Have you optimized your computer? If so what are the specs?
Posted Wed 13 Nov 13 @ 11:40 pm
ive done everything, the specs are in the original post. this is a direct connect to my desktop then streamed, you cant hear my speakers. Dpc latency checker says alls good. It only does that when im cuing or manipulating the jog wheel. if i dont do anything but press play it doesnt do that.
Posted Thu 14 Nov 13 @ 6:09 am
Looks like a Vestax controller you're using there.
Are you not aware of the long standing issue with Vestax kit on AMD processors? Just Google for vestax amd
Posted Thu 14 Nov 13 @ 6:32 am
Im reading it, it gives no info but i hear a lot of people say theres is working fine...give me a link please. but if thats the case this thing is as good as sold!
Posted Thu 14 Nov 13 @ 2:43 pm
I'd always suggest buying an Intel CPU rather than AMD. It's the best way of avoiding things like this, with both software and hardware compatibility.
Posted Thu 14 Nov 13 @ 2:48 pm
