Topic: Sound is messed up.
since v7.4 i have been good. but lately my sound is very digital, scratch is a horrible digital sound. And i dont know what happened. I did change to a Vestax vci-400, but it was good until last week. Now the sound is just horrible. Any suggestions.
Posted Mon 04 Nov 13 @ 3:24 am
Also Right now im not using my 1200s so i dont know if that is a factor...i cant test the timecode until i get my Voxoa m70...
What do you have your master tempo set at in the performance tab of the config menu?
Are you using a usb 3.0 or 2.0 connection?
How low is your latency set on you sound card? Is it set to auto in the config tab?
Computer specs: Processor? Ram? Video card?
Is the cpu monitor at the top of VDJ peaking out when your scratching?
What do you have your master tempo set at in the performance tab of the config menu? Fast Stretching....as always was never a problem.
Are you using a usb 3.0 or 2.0 connection? 2.0
How low is your latency set on you sound card? Is it set to auto in the config tab? 64ms...as always
Computer specs: Processor? Ram? Video card? amd x2 64, 4gb ram, 1gb video
Is the cpu monitor at the top of VDJ peaking out when your scratching? No, cruising at 44%
Does the sound clean up if you pull the latency backwards. Try pure scratch for master tempo, and let me know if either of those help.
ok havent unpacked from my gig saturday but ill let you know actually ill do a video...and post it
i think im good....i had the settings mix-matched....
Ok I didnt fix it. I have gather another laptop. Samsung I3, 4gigram, and im still getting pops and clicks. At even the highest latency settings im getting pops and clicks and crackles. its only happening in virtual dj. Does anybody have any ideas...
ok just to test i downloaded serato dj 1.5 and theres no static or pop clicks or crackles...so what could be causing it in virtual dj
Use the advanced stretch that truly makes allot of difference.
Make sure you don't set your asio to ultra low latency, but to low latency.
And yes... Serato .. true true true...
Support staff wrote :
Make sure that your computer has been optimised for DJ performance: https://virtualdj.com/wiki/Performance%20Issues.html
What sound card are you using?
(OP)
yeah i dont hear the pops anymore...gonna do a ten hour burn test and see if they comeback....but it seems to be better
