Sound file with bad quality just when in virtual dj, (these were recorded sounds, but are with perfect quality when listened to with VLC or WMP, and in virtual dj it shows 90bpm).
I really needed them for something, how can I procced?
Posted Thu 24 Oct 13 @ 6:55 pm
Uhm? What exactly is the problem?
You know what BPM stands for?
Or did you mean the bitrate?
Posted Fri 25 Oct 13 @ 4:59 am
Was the sound recorded at 16bit 44.1kHz? If not, you need to convert it to that standard (CD quality).
Posted Fri 25 Oct 13 @ 5:12 am
What file type and encoding did you use when you recorded them?
Posted Fri 25 Oct 13 @ 5:37 am
You can change the codec used to play the file, in the config tab. I had to do this for some karaoke rips. VDJ would only read a portion of the file otherwise. Config/Codecs section and delete the one vdj is using and add the one works for you. This might cause issues with some of your other files, but I haven't seen any problems since I did it.
Posted Fri 25 Oct 13 @ 3:23 pm
