Last night I experienced a new problem within VDJ Pro ver. 7.4. While in the the Browser window, I selected the Effects window. The Effects window opened, however the Browser window screen didn't refresh so I ended up with the Browser info overlayed with the Effects window. Every time that I selected a different window it just got added on top of the prior windows that were open. The screen at that point was such a cluttered mess that it was totally unreadable. The only way that I was able to get to a normal readable and operational screen was to reboot my Mac. I do have a new 13" MacBook Pro with a 2.9 GHz i7 and 8 GB of Ram.
Anyone else see this issue before? Suggestions?
Thanks!!!
Thanks!!!
Posted Sun 06 Oct 13 @ 3:21 pm
What almost were you using??
Posted Sun 06 Oct 13 @ 5:41 pm
Here's my setup:
MacBook Pro 13"
2.9 GHz Duo Core i7
OS 10.8
8 GB Ram
Intel HD Graphics 4000
512 MB VRAM
750 GB HDD
VDJ Pro 7.4 (Mac)
Denon MC-6000 Controller
MacBook Pro 13"
2.9 GHz Duo Core i7
OS 10.8
8 GB Ram
512 MB VRAM
750 GB HDD
VDJ Pro 7.4 (Mac)
Posted Sun 06 Oct 13 @ 7:42 pm
Were you using a custom skin ? If yes, which one ?
Relaunching VirtualDJ was not helpful ?
Posted Sun 06 Oct 13 @ 8:39 pm
I'm running Virtual DJ 7 (2 Decks): 1280x800.
However, I didn't try reloading or switching skins to try resolving the problem. Thanks for bringing that up! I'm now assuming that doing so might let me continue playing without having to resort to a reboot.
Posted Sun 06 Oct 13 @ 10:55 pm
