I have just upgraded to the full pro version 7.4 £120.00 since then I have noticed that when spin back on any deck the sound is very wobbly. (It sounds wobbly). I never had that problem with the free version. I have tried all the usual things like adjusting latency, increasing and decreasing buffers, basic all variations in config and performance. I have also uninstalled asio drivers and reinstalled them. Same with the new software. I am using it on vms4.1 any ideas? I have a gig this weekend and need to find a solution. Thank you.
Posted Sun 06 Oct 13 @ 7:08 am
have you checked here: https://virtualdj.com/contact/answers.html?id=119?
There are more FAQ's and help in the Wiki.
If that doesn't solve the problem raise a support ticket.
Worst case, you can still use your LE version while the issue is being resolved.
Cheers,
Roy
Cheers,
Roy
Posted Mon 07 Oct 13 @ 1:31 am
