Topic: BIN / CUE File Problem
I recently completed a mix using the Burn to CD option, I saved the mix to a local drive for future burning. However when I tried to burn the mix it was over the 700MB CD size, so I tried to extract the file using a multitude of different software MagicISO, PowerISO. However the BIN file appears to be empty, when you check the file size I get the folling.
Cue file - 96KB
Bin File - 0Kb
My questions are:
1 - Is there a way to recover the mix in VirtualDJ and re-save?
2 - Is there a way to repair the files as they appear to be corrupted..
HELP!!
Posted Fri 27 Sep 13 @ 9:01 am
That would Only happen if you forgot to save the file in the recording tab once you finished recording and close down VDJ, which will render the file useless...
You need to press Stop then Save the file before you close VDJ or start another recording...
I did suggest them to automatically saving when you stop the recording or prompt you "Do You Want To Save" xyz file before closing...
Another Good feature would be to "Pause" the recording, then start again...
