In the past few days I noticed that searching was not as before.
Example: Searching drive for a particular tune results in a bunch that are different names.
I need to scroll down until the one I searched is found.
Now when I search a particular folder for a tune, nothing appears.
If I search the entire drive it appears. In addition it indicates the tune
is in the folder I searched.
I did a check clean and fix. still no good.
Any suggestions??
Any suggestions??
Posted Thu 26 Sep 13 @ 2:20 pm
maybe your database is all wacked. you would wipe the database and rescan it. That might help your situation?
Has your hard drive's destination changed Ie. from say D:\ to E:\
that has caused me great issues with searches and loading files in other software in the past.
Posted Fri 27 Sep 13 @ 10:50 pm
Posted Fri 27 Sep 13 @ 10:55 pm
I changed the user name on the computer, and it is now working.
I don't not understand why, since it was fine.
Why would changing the user name make a difference?
Posted Sat 28 Sep 13 @ 7:56 am
Because of where the database is stored.
In Windows 7 the database is in C:\Users\YOUR USER NAME\Documents\VirtualDJ
If you change the user name then it becomes C:\Users\SOMETHING ELSE\Documents\VirtualDJ
Posted Sat 28 Sep 13 @ 8:31 am
That's the weird part though.
This system has been working fine until the external drive crashed.
Copied the entire backup drive, that's when this started.
Posted Sat 28 Sep 13 @ 8:39 am
Ah....only now you mention an external drive!
So is the music (and therefore the database) on an external drive?
Posted Sat 28 Sep 13 @ 10:06 am
Yep forgot to mention that before.
Everything is back again
Posted Sat 28 Sep 13 @ 12:13 pm
Next time I put the gun in my mouth, I will make sure that it is loaded. This is just too funny. Glad you got it to work.
Posted Sat 28 Sep 13 @ 5:29 pm
Knew it!!!
Sneaky Username and external hardrive issues!
Posted Sat 28 Sep 13 @ 7:52 pm
A Man and His Music
LOL
Never had this problem when I made a back up of drive before.
Actually found out about the name change by accident.
Thanks
LOL
Thanks
Posted Sun 29 Sep 13 @ 8:36 am
