hi guys having issues with locking the pitch keys im meant to b djing tonight gettin rather frustrated can anyone help please
Posted Wed 25 Sep 13 @ 9:39 am
Locking by controller buttons or keyboard...?
Posted Wed 25 Sep 13 @ 9:44 am
i lock em via keylock next to pitch bars
Posted Wed 25 Sep 13 @ 9:46 am
when i put a song on 2nd desk the pitch bar involuntary moves
Posted Wed 25 Sep 13 @ 9:48 am
Have a look in config/ options if auto pitch matching is disabled
Posted Wed 25 Sep 13 @ 9:54 am
So pitch slider is at 0%, you load a track and the pitch slider moves automatically?
If so in VDJ Config go to the Options tab and make sure "Auto Pitch Matching" is set to Disabled (which it is by default IIRC).
its starts where level in middle as soon as put track on the 2nd table it jumps up or down ive done all that in config but hash solved problem
Posted Wed 25 Sep 13 @ 10:04 am
smart play active..?
Posted Wed 25 Sep 13 @ 10:30 am
Try setting 'disengage Beatlock' in options to 'On Load' to make sure you aren't accidentally enabling beatlock.
Posted Wed 25 Sep 13 @ 10:59 am
