the pads do have different colors if this pic is correct
Posted Wed 30 Oct 13 @ 1:58 pm
Ola friends.....I downloaded Sampler48, installed it as per instructions and it won't hold the samples. What gives?
I start off at the first page and all the preloaded samples work and are saved. I goto page 2 and load a few samples, they work fine. But when I navigate away to another page then come back to page 2, the samples I just loaded are gone. Any ideas why?
Posted Tue 05 Nov 13 @ 8:55 pm
same here thats why i adapted to synths mapping
Posted Tue 05 Nov 13 @ 9:27 pm
just wanted to say thanks to all who made videos.. IM remapping the apc40 to sample meca as I understand the version 8 has unlimited samples and the idea of pages as you show me makes me wonder If I can map pages to songs and make them load so I can slam beats throw in trash and mix all at the same time.. I also just added three more controlers. I might add apac 20 and ditch my piano..Is this going to be possible in 8?
Posted Sat 16 Nov 13 @ 4:02 pm
if you want more than 12 samples use extra decks, otherwise use the sampler manager plugin to create your banks, and you can use the sampler converter webpage I posted earlier to convert the output to VDJScript that you can use in your mappings.
Posted Sat 16 Nov 13 @ 4:33 pm
