I'm having a lot of problems with my Maya 44 USB sound card. I went to download the driver from ESI's site & every single time I got the x00006 error.
Also I opened up Virtual DJ and got this error message "your sound card is probably not connected or the settings are incorrect.
I have a pretty new computer Dell Inspiron with Windows 7 from 2012.
Hopefully somebody can help me out.
Also the driver may be installed I have no idea.
Can you guys help me get everything connected?
How to connect my Maya 44 to my turntables?
What RCA cables go where.
Also help with the settings in VD.
I have it set to.
2 time codes
External Mixer
Under sound cards my only option is Asio Driver
I have it set to.
2 time codes
External Mixer
Posted Fri 20 Sep 13 @ 7:42 pm
Try another USB port & always use the same port you installed it on
Posted Wed 25 Sep 13 @ 10:51 am
