I have a bunch of DMX controllable FX lighting. It would be nice if VirtualDJ without getting two complicated outputted Sync'd DMX commands that made the lights intelligently respond to the music. This feature would be perfect if you had 32 present commands lighting programs that could be saved with the song.
I guess all you would need is a USB to DMX(midi/xlr) interface and a Virtual DJ plugin.
What do you guys think?
Posted Tue 17 Sep 13 @ 3:09 pm
I've written a simple one for a user to control his LED par cans with a beat synced colour fade, I could probably think about expanding on it.
Posted Tue 17 Sep 13 @ 3:16 pm
Nice! Thanks,
This plug would be appreciated as my lights chaotically try to react to the audio which doesn't work well. Bringing order to the lighting I believe will significantly increase the effectiveness of the lights.
Darin
Darin
Posted Fri 20 Sep 13 @ 8:45 am
You can use Freestyler with SBDJ's Freestyler plug in. I use it with ADJ Inno Scanners, ADJ Inno Rollers, ADJ Mega Tri 60's and Chauvet Colorband Pix-M's and it works very well for me. As long as all your music is BPM'd correctly.
Posted Fri 20 Sep 13 @ 9:09 am
