Hello,
I am looking for a pair of headphones around £60-70 price range which are preferably durable yet the sound quality they produce is good. Also, good noise isolation is something I'm definitely looking for. Does anyone have any good sites they would recommend where you can compare headphones? or does anyone have any recommendations themselves?
Many Thanks,
DJJC
Many Thanks,
DJJC
Posted Sat 14 Sep 13 @ 9:45 am
Posted Sat 14 Sep 13 @ 2:17 pm
Don't waste your money on a $100 pair. If you are gonna spin with them regularly they will break in under a year. I went thru dozens pioneer to top line Sonys. Spend a little bit more and get Senhiser HD-25s. I think i paid around $200 5 years ago. All the parts are replaceable cups and wires and they use steel wire so it never wears out or breaks. Five years of use 4 days a week and they still look and work like the day I got them. http://www.amazon.com/Sennheiser-HD25-1-II-Closed-Back-Headphones/dp/B000TDZOXG/ref=sr_1_1?ie=UTF8&qid=1379188619&sr=8-1&keywords=sennheiser+hd+25
Posted Sat 14 Sep 13 @ 2:57 pm
I like the Denon DN-HP1000's. Their extremely comfortable, and sound better then the middle of the road pioneers at the same price. They have excellent isolation, and typically last 3 years with 3-6 gigs a week. I drop them all the time too. You'll never regret spending a lot on you headphones.
Posted Sat 14 Sep 13 @ 7:51 pm
Numark RedWave. No questions asked. Great headphones, comfortable, slick looking, great sound. And best of all, cheap.
Posted Sun 22 Sep 13 @ 9:23 pm
