Hello, I have recently bought DJ console Numark Mixtrack Pro 2 (with soundcard) and the problem is:
I'm normally mixing, then suddenly som strange sound (cracking or something like that) appears in headphones. Only headphones, master is playing clearly. I found out I can fix it when I click on safe mode. It doesnt matter if I turn it on or off, just need to reclick it and it will stop doing that sound. After a while (usually after mix to another song) this happens again, after reclick of safe mode it's fixed again.
Any suggestions how to delete this problem with any other way like reclicking all the time?
Thank You, Regards Adam :)
Using:
Virtual DJ Pro 7.0.4.
Sound settings:
Output: Advanced Settings -> Master - speakers - 1&2
Headphones - Mixtrack pro speakers - 3&4
PC:
Windows 7 Pro x64
CPU: Intel(R) Core(TM) i3 CPU 560 @ 3.33GHz 3.19GHz
8GB RAM
Using:
Sound settings:
PC:
Windows 7 Pro x64
8GB RAM
Posted Thu 12 Sep 13 @ 12:25 pm
7.0.4 was released in May 2011...;-)
You should register your Pro Version, and make a free update ( actually we have 7.4) to ensure, that you are working with the actual Version and having Full Software Support for your Controller.
greetz
rob
Posted Thu 12 Sep 13 @ 12:50 pm
done :) I've got it now
It changed a little... the cracking is appearing less frequent and it's not that intensive like before
Posted Thu 12 Sep 13 @ 1:54 pm
if you would have registered you version, there would be a note in your avatar....;-)
but if it works...have fun...;-)
Posted Thu 12 Sep 13 @ 2:43 pm
